Hi What's the rear disc minimum thickness for the RS175 phase two? I read it's an R26 setup? So if the same part, the numbers still apply. Mine are on 10.64mm and look a bit shallow.
Yes it's 11mm maximum (new) and 9.5mm minimum. I note that standard (230 F1), cross drilled (R26) and grooved (R26R) are available as original Renault parts. Any preference for the dCi?
