As title says..does anyone know anyway of getting the rear discs off, I've tired a hub puller which bent, another hub puller which only slightly moved the discs...struggling for ideas other then getting a 10ton hydraulic hub puller.
The bearings are built into the discs, so if you're replacing the discs then it won't matter if the existing ones get damaged.
