Hi all The time has come for my RS 275 CUP to change the rear brake discs. I've tried to order Brembo 08.A753.47 and the seller is telling me that he can see that these discs won't fit because of the height being 104,7 not 106. Are the rear discs for 2016 RS 275 CUP models different? Also. I'll fit Pagid RS42 pads on the rear discs and I have in front 355x28 Reyland Motorsport floating disks with Pagid RS29 pads. Are the Brembo 08.A753.47 discs good enough or should I go with other discs? Thank you
08.A753.47 are for grooved rear discs which earlier 250 and 265 cup models ran. 275 cup switched to plain discs, part number for those are 08.A753.37 but both plain and grooved option discs will fit. Stock discs are good and can take a fair bit of abuse.
