Anyone done this on a r26? I got offered about £60 to get it done but if its not rocket science why waste £60?!
I've heard kwik fit are good so booked a re gas and a 'ac cleanse' for £69 on Friday there the re gas was £49 from them
I got mine gassed for about £30 then still no joy. Got air con tested and discovered a hole in the pipes and the unit itself was knackered. £400 later now sorted and vent temp is around 6degrees.
The window option was fine but on a scorching hot day in the rain, there is a slight flaw in them plans
This system (Mk 2) leaks from 3 places. Inlet to cooler Either inlet/outlet from dryer inlet to cooler matrix (in the dash) Any leaks and it'll be either of these joints; pence to clean the seal and re connect (if you're unlucky it'll be a hole in the cooler, easily replaced £60 for the part). It's just a pain in the ass that you don't need, however....the moral is, don't buy French; but we knew that anyway! There's a lot to be said for the open window and the wind in your hair (along with the buffeting in your ears!). Paul
