Rattling Dash F1 R26
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by andy17898, Jan 13, 2014.
  1. My dash is rattling, seems to be by thwe steering column and the speedo. Any easy access screws i can get to to tighten, or anythign else you can think of?
  2. Its not by the windcreen is it? As i've heard thats quite a common problem, havent had it myself but have heard silicone lube spray can help
  3. iv found its the dial visor bit. it just pulls off if your needin to put a small amount of foam round it to stop the two surfaces rattling. also the windscreen is another place for a rattle as jjones82 says above.
  4. Yeah it is the visor bit. Does it deffo just pull off? Ooh err!
  5. Spray some silicone spray at the back of the dash, it's the foam that rubs against the front screen. Mine sounded like I had 1000 mice behind it! Done mine 6 month ago and been fine since!
  6. silicone spray? wd40 do? it deffo sounds like the speedo visor though! Its definately a rattle as opposed to a squeak though
  7. Mine sounded like it was coming from the heater display!
    I used silicone spray, not sure on WD40 to be honest
  8. aye the dial visor has 2 clips if i remeber correctly and a good hard tug towards you and it comes off.
  9. where di you spray? I will try that first!
  10. If you look where the dash meets the windscreen you'll see some foam, I just sprayed the foam all along the windscreen
