225 rattle vibration
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by 3 crispies, Nov 29, 2015.
  1. just changed oil and found plate (wuth 4 x 10mm nuts recessed) under gbox was loose. found bolt missing so removed cleaned and refitted now car sounds like a bag of nails. will look when home is plate incorrectly firred ????
  2. matt e
    does it go across the subframe?
