HEL lines hopefully are on the way.I contacted kevin from KAM.He said they were being made at HEL.After he told me he had them in stock!Its been a wek now,so hopefully they have been posted.
fine...did a circuit round my house of a few miles.All seems good.cars idling fine when warm.Just went far enough to warm it through.
i tell you ian,this yugo`s gonna suit you right down to the ground!..which is appropriate...as its been run into the ground
You didn't go around the mini ring with your mates then That's good it's still running okay. Be back on yours again tomorrow
I'm sure you could have kept up, its got a good heave of torque in the mid range Boost comes in lower than that. On the top of the right hand stalk, there are two buttons, hold them both down for a couple of seconds and it turns on the \rs monitor, the button right at the bottom is the "okay" button, you can then see the boost gauge
While the hubs were off i thought it would grease the lower bearing, removed the bolt and filled the hole with grease 2020-05-11_07-01-47 by Ian Austin, on Flickr Then screw the bolt in by hand, if the grease doesn't come out like this 2020-05-11_07-02-02 by Ian Austin, on Flickr Then do it again.
New roll bar bush's fitted, subframe refitted, suspension unit also fitted. Then there was the issue of fitting the track control arms, oohhhh that went easier than it ever did on my 225, refitted the drive shafts, the long one i replaced the bearing last week, now i hate standard suspension to much movement, the hubs were so easy to fit to BC suspension, but with the 3 yards of travel in the standard shocks, i had to remve two of the strut retaining bolts a loosen the other, now the suspension unit can move to the side and i can fit the hub to the strut, then pushing the control arm down fitting it onto the arm So all that is left really to do to the front now is fit the bumper, disc's and the new Hel brake lines (they arrived today at 17.45) hoping to get that all finished off for tomorrow. Then the rear end the day after, maybe
£100 an hour Even more for quality cars Well i'm sure if BMW can charge £117 + vat and you get the apprentice to work on your car
we did the swivel hub bearings about 2 years ago....the needlerollers in the bearing were seized solid!always interesting when you turn the steering wheel,and it wont turn anymore when it hit a tight spot!
Two years ago, i think i changed mine before 2 years, well i drive mine anyway Well there all greased up again so should be good for another 2 years at least
I knew that, when i was looking for big end and main bearings i saw that they were the same as lots of old Renault engines
caught mine just about in time...we could just about save the turrets from inside the roller bearing. many people will reuse fkd turrets,that will make those needle rollers fail prematurely..
Today Replaced the brake lines and fitted some Hel brake lines, caliper bleeds were corroded, went off with quite a crack when they let go, cleaned them and smeared with some grease. Managed to change the pipes and no bleeding required Fitted the arch liners, cleaned the hub faces and the disc's, also drilled out all of the holes in the disc's, this is why i have plain before IMG_20200512_102312 by Ian Austin, on Flickr After IMG_20200512_102808 by Ian Austin, on Flickr The holes were filled with pad material, had this same problem on my Mercedes, they filled up and compressed that much that the brakes were very poor, couldn't be bothered in drilling them out so i bought new disc's and pads
carbon pads i suppose dont do these type of disks any favors...just basically filling them with metal based particles!
i just found with the xp8`s..if you dont have some abrasion like holes or slots..the pads just tend to glaze over,and you lose bite.
Yeppp had to drill every one out the rears need doing as well, will definitely getting a photo of them
Bumper got put back on, under tray refitted. Then refitted all of the trim bits around the engine bay, wheels put back on and the car lower back onto the floor. Then to start on the rear beam. disconnect all of the brake lines, handbrake cables, abs sensor cables. Everything was covered in mud, so dusty touching the pipes and cables just released more it's out and on the floor waiting for the new bushes to be fitted (tomorrow) along with the new springs. IMG_20200512_172430 by Ian Austin, on Flickr Also going to have a look at this and see if it can be repaired IMG_20200512_172644 by Ian Austin, on Flickr
probally you cleaning out those holes will make a big difference to the bite from cold...didnt relize they were clogged like that.
Everything has been changed on this car now!..oem springs alone were £400!....I don't think they are available anymore now
Todays job Change the rear beam bushes, quite easy to get out, the casing of the bush is plastic, if you wedge a screwdriver or a tapered punch between the bush and the beam cup, this then collapses the wall in and then you can drive the bush out with a hammer. To get them back in i had to used a big thick washer as big as the new bush, a metal plate and some 10mm stud bar, smear the inside of the housing with some grease and wind the nut down the stud bar and it pulls it through. Before, drivers side IMG_20200513_103953 by Ian Austin, on Flickr Passenger side IMG_20200513_103904 by Ian Austin, on Flickr and one of the new ones fitted IMG_20200513_113055 by Ian Austin, on Flickr also replaced the rear brake flexies
Looks like it doesn't it, you will have to try it on roads you know to see if that problem has gone, the M5 A38 didn't show it up I took it on a road i use for testing, i would be happy with it
it handled ok ..but had definitely lost some of its unshakable road ability. hopefully with all these new items it will be back to rude health!
