can someone please confirm which switch is the reverse switch on an R26. Got the passsenger wheel liner out and there's a switch horizontally mounted into the back of the box and also a vertical switch on the top of the box under the battery tray in front of the selector. I'm getting confused as both of these don't have the connections that match my new reverse switch 82 00 177 718 that RPD sent me. Not sure if the switch is the wrong one or I'm just looking in the wrong place. Thanks
Thanks. Thought it must be that after I got a multimeter on it. Looks like I have a 3 contact connector switch and not the R26 one. Mute point as it turned out to be the 10A fuse instead. Reverse lights work now. Reverse camera still doesn't and stumped as to why? Wiring continuity checks out OK and head unit settings are fine but still just a black screen when put in reverse?
