R26 rear washer jet
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by charlie1984, Dec 10, 2014.
  1. Mine also just pisses on the rear screen.
  2. you're lucky mine does my headlight washers instead but my prob is with squib/stalk, thought about taking rear wiper off cos it costs a bomb even used one on ebay is £150 or best offer atm just glad its my rear washer and not front or lights
  3. My front washers are garbage i have to rely on the headlight washers to splash up onto the screen.
  4. It may be also begging of the end for pump. I experienced it with company car - Kangoo 09 reg. Primarily pump wasn't strong enough to pump water towards rear windscreen, then even front washers stopped working. It is wort to check it, as it costed only £40 fitted in local garage.
  5. The water squirts out with good pressure... But just didn't hit the rear screen.. And when I looked there was a hole.. Where it looked as if there should have been a jet nozzle..
