Hi boys, i have the projectors set at the max hight, but they still not high enough i think, is it possible that the adjustment wheel and the projector hight is not sinchronized? I literally see nothing more than 10m away!!!
Beam setter is what they use on an mot to check the lights are at the correct height. If you pop into a garage they could check it for you. As said, bulb could be in wrong or if you have xenons one of the level sensors rods could be broken.
