R26 Cabin vibration
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Dean250, Jan 17, 2015.
  1. I've been getting some cabin vibration that can be felt at idle that I want to get rectified.
    I've had the engine mounts checked and they are apparently ok, there is also no movement in the gearstick under acceleration.
    The car is on 49k, engine runs fine and ticks over at around 800 rpm.
  2. Its always the top left mount, mine did it too got it replaced with the cambelt problem solved
  3. Yep that'll be the one
  4. Cheers guys, the one on the drivers side? any ideas on replacement costs? genuine or worth uprating and are the easy enough to fit?
  5. Their easy to change dean, I wouldn't update it mate just replace for OEM, I'm sure mine was around £60 from adds
  6. Thanks Steve, will get an genuine one sorted out then need a few things!
