R26 275bhp 70k £5500 - SOLD
Discussion in 'Cars For Sale' started by mike123456789, Aug 7, 2017.
  1. Hi all.
    Thoroughly enjoyed my time with the Megan but my Wife is due to give birth in 4 weeks so want to free some cash up - and by an R53 mcs.
    Car is a 2007 "57" Megane R26 Lux edition, it has all the keyless entry/start, auto lights and wipers. Climate control and cruise control. Full leather Recaro seats with full leather bench all in mint condition.
    FSH, 1 stamp is missing early on before I owned the car (second year service springs to mind)
    It had a major service on it last time , spark plugs , oil , filter , air filter cleaned. And since then I have changed oil and filter again and changed gearbox oil.
    About 11months mot which had 1 advisory which was a cv boot clip only.
    Engine spec - the usual 230 engine -
    Mods- Forge front mount intercooler , Ktec plated induction kit , Properfect recirc valve, milltek 2.75" cat back Unsilenced system , Deka 630cc injectors, Scan gauge.
    Cambelt was done by Birchdown along with waterpump and aux kit about 3 years ago.
    2x new engine mounts on the left side (top and upper swing) and also a polybushed lower swing mount
    Mapping has been done by Paul at RST.
    Transmission - Standard R26 gearbox ND0-020 , which has been completely stripped by Brosport , 2nd gear, hub syncro & sleeve were replaced , and the rest of the box inspected all okay (I have invoices on all)
    Upgraded later R26R Clutch , new genuine Renault slave cylinder
    RS tuning TTV single mass flywheel
    New flywheel bolts
    Also replaced the rear main crankshaft seal at the same time as there was a small drip
    Lee boardman Short shift lever
    Brakes -
    All done less than 5k.
    Brembo HC discs and pads.
    Braided Brake lines.
    New genuine rear disc and pads with new bearings and ABS rings
    New NSR brake caliper
    Steering -
    Last 10k miles
    New genuine Renault inner track rods , track rod ends , New NSF lower arm
    NS Hub bearing done by Mark black.
    New anti torsion and ARB links.
    Brand brand new Michelin Pilots Sport 4s.
    A very sexy re leathered steering wheel by Royals in Nappa leather with Red stripe at 12oclock.
    General replaced items ,
    LED front fog lights
    LED number plate lamps (not the cheap bulbs)
    Genuine Renault R26R Spoiler
    Genuine Renault R26R "black insert" Headlights ,
    HID 6K upgrade , with LED sides
    Lights
    LED reverse lights
    This car genuinely wants for nothing and doesn't require any jobs.
    Comes with a private plate RS57 MEG.
    20170603_131638-1.jpg 20170603_131646.jpg 20170603_131653-1.jpg 20170807_132701.jpg 20170807_132701.jpg 20170807_132715.jpg 20170807_132729.jpg
    renault-renaultsport-megane-renaultsport-f1team-r26-S2860540-6.jpg 20170801_170128.jpg 20170603_131550-1.jpg 20170603_131600-1.jpg 20170603_131608-1.jpg 20170603_131617-1.jpg
    F1 2.0RS, lazio_troy and imprezaworks like this.
