R-link dispaly fault
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Andy P, Jan 17, 2015.
  1. Long term problem for last 5 months. RS 265 S/S
    Dealer has tried and 3 updates done to R Link
    Repeatable fault. R Link shows N in display despite what gear it is in and no bar graphs or gauges work.
    [Start Stop does not function.]
    I take it it uses clutch switch but as cruise and speed limiter works perfectly may not be that.
    Does the Gearbox have a sensor?
    Is it accessible, cleanable, replaceable?
    [Conditions are get car hot, stop for 10 minutes, malfunctions. Sometimes if stopped and car locked unlocked on key card or put in slot restarts system.
    After long hot run seems to 'dry out' and works okay.
    If Gearbox sensor I may aske dealer to check/change
    Cheers Andy
