Question no dash lights ?
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Darranr26, Nov 19, 2015.
  1. Just been out in the car,and everything was fine but then got back in and had no
    Dashboard lights no Rev or speedo anyone had this fault
    I've got a side light out and a indicator bulb out too but don't think this would cause it ??
  2. Turned off and try again, my clio 197 was glitchy now n again, all lights apart from clocks, restart the car abd they came back on.
  3. Yeah done that and it sorted itself out
    Bit weird
  4. I've had the same thing a few times in my 225, just needs to be restarted and all is fine again
  5. Mine did it the other day aswell
  6. Mine just done this but the old switch on n off technique not working really stumped now need a fuse layout of the ones under bonnet so i can check them
  7. yea I've had this, simply turning the lights off and back on works for me, it usually happens after I get a message on the dash saying something like auto lights disabled, the lights are on and working fine but I lose the speedo/rev counter lights. Still no idea really what this means as I don't change anything.. but I guess seeing as this is the only electrical issue I have bar the drivers side window I should be happy!
  8. Some times you have to open the door after turning the engine off due to auto light feature. Had to do this with mine.
