Q: Which Megane 225/230 engine upgrades to 300-320bhp?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Raptor6767, Sep 6, 2014.
  1. What do I need in order to run safely 300-320bhp?
    I'm thinking of doing an engine swap from the Megane to the Clio 197.
    TNX!
  2. I think over 300 to be reliable would require uprated internals.
  3. Pistons only, or the con rods too?
    Anything else?
    Hybrid turbo - which one proved to be the best for the Megane?
    Injectors - which ones if necessary?
    IC - need to see which one would fit best in the Clio
    downpipe
    Anything else?
  4. Salty
    Salty RSM Moderator
    both the same engine and req forging for over 300lbs/ft
  5. I think the rods are the weak link, IIRC they're the same as 182 spec? Be silly not to stick some pistons in if you have all the rods out...
