Project: MRS2: Conversion Quaife ATB & Metal Catalyst
Discussion in 'Megane Projects' started by arno samimi, Feb 18, 2015.
  1. all needed parts:
    removed from above:
    also from below:
    already out:
    fixed on the holder:
    dissembled is fast:
    unpacked the ATB, unscrewed the crown:
    mounted new bearings, screwed the crown:
    inside and is already turning by itself:
    mounted the other parts:
    all cleaned, apply the sealant and mounted the cover, mounted the outer parts and ready to install in the MRS2:
    back into it:
    all mounted from below:
    also from above:
  2. again a familiar image:
    finish:
    not to forget to fill in the lifetime warranty card and send it to quaife:
    at the same time installed the metal catalyst:
    yet installed here, space completely filled:
    without mounted gearbox and front axle, very easy to dissamble:
    conversion both lambda sensors:
    mounted the metal catalyst and it remains very much space:
    from above also all good. all connections are in the right place:
    mounted the shield, looks like original, finish:
  3. [video=youtube;aoubSrmrrao]https://www.youtube.com/watch?v=aoubSrmrrao[/video]
  4. You make it look all so easy lol
  5. :wink:
  6. It's easy. Looks worse than it is. Really...
