test mounting: dissemble: parts painted: all mounted without cushion: a part of the perfect fitting leather to the rest of original leather of the MRS2 brought to perforate, and then inked the hole-edge by hand (two zones per seat have two-tone perforated leather): "Renault sport" lettering adapted to the mRS2 version and further added "megane trophy": and below "recaro" replaced with the serial number: fitted the seat harness from the megane with seat heating etc. now you can replace the seat as plug & play: of course the heated seats is also works as original: and so they look now:
thanks all! as now seen, the seat holds by itself in position, if you're not holding him. but you can still continue to push forward the seat backrest. and seat himself also goes further forward if need be.
