Hi guys, dunno no if im paranoid or what but my car use to say Press brake or clutch and start.. Now it's only saying press brake? Is there a problem or? anyone else experienced this?
Mine says press clutch don't recall it giving the option?! does it's still start if you depress either?
Mine says press brake. But works off either clutch or brake. (Unless in gear then it wont start on the brake. )
Im sure it works like this guys .....press brake (if gear selector is in the neutral position) or press clutch ( if in gear).
When I'm in neutral it use to say press clutch or brake and start. Now it says just press break. It's a Megane Rs 250.
Like others have said, if it mentioned the clutch you would not have been in neutral (or the car was confused but is now ok).
