preparation / restoration megane r26
Discussion in 'Megane Projects' started by LoK28o, Dec 22, 2019.
  1. i have heard you speak Swahili after a 3 liter bottle of cornish rattler!
    manugtt likes this.
  2. Is that what it is, i can't remember with that many beers :blush::blush::blush:
    manugtt likes this.
  3. :tearsofjoy::tearsofjoy::tearsofjoy:
  4. do you know if these gaskets come with the renault kit?
  5. You need this stuff
    https://www.ebay.co.uk/itm/Victor-R...614517&hash=item469424c3fe:g:j24AAOSwoddaa0Un
    Just make sure the surfaces are clean and oil/grease free, you can put the bearings in and torque them down, you can do all of the other assembling but leave the sump off.
    When the Reinzosil turns up, fit the nozzle, cut the first step off, then you need to squeeze the sealer in the grove until you can see it seep out the sides all the way up.
  6. noooo the photo. is what the engine had its origin.
  7. if victor reinz of boards. I have in the workshop.
    then it says mount and tighten. then everything dry and clean, I put the spout of the joint former. put it in and squeeze until it blows all over the place
  8. That correct, it is the only thing that stops the oil from the sump getting into your clutch, well apart from the crank seal
  9. Really, that strange, mine had the sealer stuff and i know its never been stripped
  10. yes that is strange yes!
    me, by taking that out. and see that it had juntas. I've gone crazy, looking for those gaskets in spare parts
  11. So you are going to have this up and running by the weekend :sunglasses::sunglasses:
  12. hopefully!
    puremotorsport does not reply to emails. and I'm getting nervous
    because I have neither money nor pieces!
  13. What is it your waiting for ???
  14. complete engine gasket kit
  15. That still not arrived, he's normally really good
    Do you want me to give him a call for you ???
    manugtt likes this.
  16. It is rare, because from the 22nd day of the order.
    put pending shipping. but they don't tell me anything.
    if you can ask, to know what happens.
    I would be calmer
  17. What name is the order in ???
  18. sergio rodriguez lopez
  19. Hi Mate
    I have spoken to Nick and he has posted the gasket set today :sunglasses:
    manugtt and LoK28o like this.
  20. yes i just got home and check the email.
    How happy it makes me, to see that on Thursday I have all the material
    Thank you very much for the inconvenience
  21. They were on back order apparently, thats why there was a delay in him getting stock back in
  22. the same delay I have with the engine hahahaha
  23. Any recommendation?
    of any kind of improvement? now i'm on time
  24. Bigger turbo :laughing::laughing:
    Just get it built so you can use it, have you done the short shifter modification yet ???
  25. hahaha if the turbo is very expensive.
    something cheaper and that is an improvement for the engine
    if the lever is already modified
  26. That the way, one step at a time :laughing::laughing:
    Maybe next year :sunglasses:
  27. I mean, some improvement. but not as expensive as the turbo.
    right now spending 2000 € ......... it's impossible
  28. Your better getting it it forged and doing the turbo at a later date, than the other way around
  29. I already have my dear and desired engine gaskets
  30. When did they arrive ????
  31. Motor arrancando para el fin de semana oiga!:tonguewink:
    Engine running this weekend sir!:tonguewink:
  32. this morning
  33. I hope, but I don't think so.
    I still ask for some things and they will not arrive on time
    ojala, pero no creo.
    igual pido unas cosas y no llegaran a tiempo
  34. I'm trying to get a gasket set for an engine i'm working on, going to be at least 6 days maybe longer :rage::rage:
  35. do not remind me that!
    I a month. waiting
  36. the water thermostat. I am looking to change it. Any recommendation? larger? colder?
  37. No, i went aftermarket of the same temperature and i have not had any problems
  38. You cant go bigger as it fits in a housing, you could drop a couple of degrees, but the ECU might think its not quite warmed up and add extra fuel, this is what it does if the thermostat goes wrong (opens at lower temp)
    manugtt likes this.
