preparation / restoration megane r26
Discussion in 'Megane Projects' started by LoK28o, Dec 22, 2019.
  1. I will see if i can find some old bearings and do a video for you
  2. ok thanks friend
    if so easy it is. I still cheer up tomorrow. and I ride it all. I really want to finish it
  3. Just take your time and look often, once you have done a couple, then you will build up confidence
    JUST TAKE YOUR TIME
    :laughing::laughing::laughing::laughing:
  4. with more fear than shame.
  5. measurements
  6. Little time. let's say 30 minutes
  7. do you feel better now the jobs done :laughing::laughing::laughing:
  8. With this kind of job I use to be scared too, one fault and the worst can happen!! But must to be brave in life man:wink:
    Good for you
    ianplymouth likes this.
  9. Got to believe in yourself :laughing::laughing::laughing:
    manugtt likes this.
  10. Absolutely, but first times...:sweatsmile:
  11. he's just a worrier :laughing::laughing:
    manugtt likes this.
  12. Now I am calmer and happier. but fear does not take away from me anyone hahahahahaha
  13. a little bit of today
    Eder likes this.
  14. Hello friends. I have a question.
    What engine compression did it leave? wanting to look for the 400hp later? 450hp?
    What compression ratio do we have as standard? 8.5.1?
    I have always read, that to gain cv to a turbo engine! it is better to lower the compression a little.
    and I don't know what compression to look for
  15. R26 and 225 is 9.0-1, 250 is 8.5-1, they use the same pistons though but the difference is in the head.
  16. @LoK28o Are you using standard disc's with those mk3 calipers, if so why :openmouth:
  17. and what compression ratio would you leave? or what relationship do people leave for racing engines?
  18. noooo is the whole kit of the 3. discs and calipers
  19. When i looked into this when forging mine and spoken to EFI, he said for me to leave the compression as it is, by lowering it apparently will make it worse to drive off boost.
  20. So where are the 5x108 holes ????
  21. I was thinking of giving him the compression of megane 3. since the difference is little.
    But the truth is that I don't know what compression to give
  22. they are the same holes but displaced
  23. Who are you telling what the compression is ????
    Just use the forged pistons, if i were you and if you want to lower the compression, then really the only way is going to be a one off made head gasket that's thicker.
    Or you can have pistons made, but that's not a cheap option
    Standard compression for the 225 and R26 is 9.0/1
  24. So you elongated them, couldn't see from the picture
  25. if they are just a little long
    there is a little less hahahaha
    manugtt likes this.
  27. Little by little that is seeming a engine...a good one!:grin:
  28. cubing motor. to look for compression ratio. and almost everything is ready
    ianplymouth, manugtt and Poppaboost like this.
  29. looking good there matey, should be up and running for the weekend :sunglasses::sunglasses:
  30. hope friend, with the covid 19 problem all the pieces are late
  31. What do you mean, i am ordering parts and there coming next day or the day after, who have you upset :laughing::laughing::laughing::laughing:
  32. Well, I asked for the cylinder head gasket on Thursday. They tell me that it will arrive on Tuesday or Wednesday.
    all engine gaskets and seals, ordered at renault monday. I still don't have a delivery date. in Spain this is laughable
    manugtt likes this.
    manugtt likes this.
  34. I have bought from these, for my 225 (250 engine) and my 265, not had a problem with either set
  35. I don´t know, but the oil pump system, with that simple chain...don´t convence me much!!:tongueclosed:
  36. but here the cast is very bad. or so all the messengers tell me
  37. Thank goodness that later it has a skid or tensioner. that leaves something better. I don't like it too much either hahahaha
  38. Mine after 115k miles, i don't see a problem
    49323821953_cd79bdaba1_k.jpg oil pump by Ian Austin, on Flickr
  39. the truth is that my oil pump. it looks new and the whole kit too
    but I better put everything new and stay calmer
