Powerflex group buy
Discussion in 'Group Buys' started by Boardy, Jun 11, 2015.
  1. Gray
    Gray RSM Moderator
    That's worked out well and QUICKLY!
    Grear work guys...
  2. I would like:-
    (PFF60-821) UPPER ENGINE MOUNT INSERT X 1
    (PFF60-525) GEARBOX MOUNTING BUSH INSERT x 1
    And to let people know I did the arb bushes last night and it is a sub frame off job, you could probably do them in situ but with major trouble/ faff I had my engine out and still found it easier to drop the subframe
  3. These for me please:
    PFF60- 525 gearbox mounting bush insert x1
    PFF60- 821 Upper Engine Mount Insert x1
    PFF60- 820 Lower engine mount insert x1
  4. Sorry for the slow replies gents in still stuck in work, I will update the list when I get in.
  5. JAMES157
    PFF60-821 upper engine mount insert x 1
    PFF60-525 gearbox mounting bush insert x 1
    PFF60-503-20 Front anti roll bush 20MM x 2
    Total 4
    Gray
    PFF60-525BLK Gearbox Mounting Bush Insert x 1
    PFF60-821BLK Upper Engine Mount Insert x 1
    PFF60-524BLK Rear Lower Engine Mounting Bush x 1
    PFR60-510 Rear Beam Mounting Bush x 2
    Total 5
    Ianplymouth
    PFF60- 503-20 Front anti roll bar bush 20MM x2
    PFF60- 501G
    Front Arm Front Bush Camber Adjustable x2
    PFF60- 502G Front Arm Rear Bush Anti-Lift & Caster Offset x2
    PFR60- 510 Rear Beam Mounting Bush x2
    Total 11
    Ginge191
    Total 2
    Chris
    PFF60-525 Gearbox Mounting Bush Insert x 1
    PFF60-821 Upper Engine Mount Insert x 1
    PFF60-524 Rear Lower Engine Mounting Bush (late r26, cast aluminum mount) x 1
    Total 3
    Midnightrunner
    Total 3
    CraigRS
    PFF60-820 Lower Engine Mount Insert x 1 (225, early r26 fitment, black rubber covered mount) x 1
    Total 3
    Eltel21
    Total 2
    Just-that-ek
    Total 5
    Jjones82
    Total 2
    Giles
    Total 3
    grant total 43
    The bloke has has not emailed me back today with how he wants us to pay, but im back in work tomorrow so he may email then.
    Will let people know ASAP
  6. This should happend like a month ago...
  7. Some codes have blk at the end what's this mean?
    Plus can I add PFF60- 820 Lower engine mount insert x1 or is that negated/not needed as I've ordered the Bush?
  8. If you have a look on the powerflex site they have the standard yellow inserts/bush but they also do a black series which is track focused, were as the yellow are a compromise but still stiffer than standard.
    You will only need one or the other mate, the early 225/R26 have the 820 insert (covered in black rubber) and the later R26 has the 524 bush (cast ally mount)
    I don't know when they changed over, mine is a 57 plate and has the black rubber covered mount.
  9. Great thanks. Can you add me for the blk then please. I presume mines a late one being registered August/September 2008. Cheers for the info. Is there anything else that would make a noticeable difference?
  10. Yeah no problem mate, I would have though so but might be worth a quick look?
    I think you would notice the difference with all of them but, by the sounds of it some are a right pain in the arse to change.
    I'm probably not the best person to ask anyway as I'm still relatively new to the Meg!
  11. Gents, I have been told by another member that mark from Whybee has gone on holiday! Which is why he's probably not replied to my last couple of emails.
    I'm not sure how long he's away for it, it could just be a long weekend or a few weeks?
    So this could delay the order.
  12. I'm in no rush
  13. Ditto. No rush!
    Sure my beam won't fall off.......
  14. Same here.
  15. Ahhh bo**oks, i want mine now :mad:
    Not really, was hoping to have the ARB bushes because my gearbox is coming out, but not to worry its not your fault :smiley:
  16. Leave it with me anyway, I'm sure things are not going to grind to a halt because he's gone away, somebody else must take over!
  17. Been looking around and found I might have a 21mm front anti roll bar, can anyone confirm the size on a 225 Trophy?
    Don't want to order the wrong ones.
  18. Gray
    Gray RSM Moderator
    The only way to be sure is measuring your ARB.
  19. Thanks Gray.
    Boardy is it ok to change my arb bushes to the black ones either 20 or 21mm depending on what size it is?
  20. Yeah no problem mate, still need to find out when when the fella is back from holiday!
  21. Just measured it, definitely 20mm.
    (PFF60-503-20BLK) FRONT ANTI ROLL BAR BUSH 20MM
  22. No problem mate will keep your order the same
  23. Naith
    I'd be after both engine mounts. Got gearbox one already. I'll amend my post tomorrow with part numbers.
  24. No problem mate
  25. JAMES157
    PFF60-503-20BLK Front anti roll bush 20MM x 2
    Total 4
    Gray
    Total 5
    Ianplymouth
    PFF60- 501G Front Arm Front Bush Camber Adjustable x2
    Total 11
    Ginge191
    Total 2
    Chris
    PFF60-524BLK Rear Lower Engine Mounting Bush (late r26, cast aluminum mount) x 1
    Total 3
    Midnightrunner
    Total 3
    CraigRS
    Total 3
    Eltel21
    Total 2
    Just-that-ek
    Total 5
    Jjones82
    Total 2
    Giles
    Total 3
    Naith
    Naith do you want these of the black versions mate?
    Total 2
    grand total 45
    Right gents Mark has emailed me back today and has asked for payment by paypal, I have cleared my inbox so could people please PM me their email address that their paypal account is linked too and he will send you an invoice for the amount.
    If you have ordered anything else from the other group buys can you let me know in the PM and I will ask about combined postage
    And one last thing can you please just double check your order!
  26. Pm sent.
  27. Sorry about that last post, the cut and paste did not come out to well!
  28. Pm'd
    I think; on my phone and it's pretty gash!
  29. Pm'd.
    Order is all correct.
    Many thanks for sorting this all out.
  30. I've pm'd you mate. Cheers
  31. Yeah got them thanks gents
  32. JAMES157
    Total 4
    Gray
    Total 5
    Ianplymouth
    Total 11
    Ginge191
    Total 2
    Chris
    Total 3
    Midnightrunner
    Total 3
    CraigRS
    Total 3
    Eltel21
    Total 2
    Just-that-ek
    Total 5
    Jjones82
    Total 2
    Giles
    Total 3
    Naith
    total 2
    grand total 45
    Gents I'm still waiting for email addresses from -
    Ianplymouth
    Chris
  33. PM sent
  34. Sent mind drone other thread just dude
  35. Have I missed out on this Boardy?
    If not, my order is:
    1 off PFF60-524
    I can pay immediately.
    Thank you.
  36. No you have not missed out mate, but we need to pay via PayPal, I will pass the order onto the supplier and they will send you an invoice through.
    Is this ok for you?
  37. Thanks for the emails chaps.
  38. Awesome Boardy, cheers.
    Yes that's no problem.
    If you haven't sent the order yet, please could you make it a PFF60-524BLK instead?
    Should I PM you my email address?
    Thank you.
  39. I will be sending it tonight so will add your order to it.
    Yeah pm me your email please mate.
  40. JAMES157
    Total 4
    Gray
    Total 5
    Ianplymouth
    Total 11
    Ginge191
    Total 2
    Chris
    Total 3
    Midnightrunner
    Total 3
    CraigRS
    Total 3
    Eltel21
    Total 2
    Just-that-ek
    Total 5
    Jjones82
    Total 2
    Giles
    Total 3
    Naith
    total 2
    Deadmau5
    Total 1
    grand total 46
    Right that's it thanks chaps, I have got everyone's emails, I will leave this open until the morning and I will send the final list off.
    If anybody wants to jump on this can you please let me know tonight or first thing..
