265 Please Help - Changing Injectors
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by tunmo, Nov 12, 2016.
  1. Hi guys,
    can you help me with this problem that I got when changing the injectors. I've already at the final steps -- but I cannot remove the bolts that hold the fuel rail. I cannot get in with either a spanner or a ratchet to remove either of the the bolts. The left one was only accessible from underneath, where I cannot see and has very tight room. The right one can be seen but not possible to be removed due to the tight access.
    Can you recommend any special tools that can be used to remove the bolts(and put them back)? Or is it really impossible to to do without remove other components from the bonnet? Thanks.
  2. Just a put and extention ... its under the manifold... super easy to change.
