Please help before I torch the bloody car !!!!!
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Jaysport, Feb 24, 2015.
  1. Afternoon all, I have had a lovely day replacing my clutch master cylinder, that part was easy,
    but trying to bleed the poxy car is driving me insane, iv tried the usual pipe on nipple , open valve slightly and let naturally bleed , NO JOY
    iv tried the same way as I would bleeding brakes , upending and shutting valve, NO JOY
    I'm now waiting for a mate to drop his easy bleed round so I can try that,
    please any pointers before I torch the car, :mad:
  2. Reverse bleed it
  3. Hey Jay, its normally easier with 2 people, bit of a funny design tbf where the nipple is / stupid clip design.
    A few people reverse bleed them with a syringe, worth a shot if you haven't tried it?
    Edit :- beaten to it
  4. Forgot to put that in my first post, tried reverse bleeding it to,
    I now have the eazi bleed system in my grasps so will be giving that a go ,
    can anyone help me out on that,
    from what I gather
    I connect it up to the break res
    Fill eazi bottle with fluid
    connect to tyre at around 20psi
    Then pull that poxy bleed nipple back slightly and let it drain ?
    Is is that right ,
  5. did you pre-fill the new slave?
  6. Hi MJ57 it was the master a changed and no didn't pre fill it , read about doing that somewhere after I had fitted it , thought that was only on the slave cylinder though
