250 Pk4019 gearbox bearings
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Jamie230, Jun 16, 2022.
  1. Hi all,
    I have a 250 with a pk4 019 gearbox that i have stripped to replace the diff but i have found a few bearings are not good so want to replace them all. I need 6 in total as the diff came with new ones but i can only find kits for other pk4 gearboxes and not the 018/019. Does anyone have any info on them and where to buy them? They may be the same as what i see online but don’t want to order anything unless I’m sure.
    thanks
  2. ianplymouth
    Here you go Jamie
    The bearing part numbers are there as well as the bearing sizes, i made a note of the sizes and went to my local bearing supplier and he had most in stock but had to order in a couple.
    They were better quality than stock Renault ones and way cheaper.
    http://www.catcar.info/renault/?lan...OT01fQlZJST09MDE5fHxOT01fQlZJSV9TSUdOPT0gPSA=
    http://www.catcar.info/renault/?lan...8Y3JudE5vcHI9PTEzMTh8fHJlZmFjY2VzPT1OMjE0MjM0
    http://www.catcar.info/renault/?lan...8Y3JudE5vcHI9PTEzMTh8fHJlZmFjY2VzPT1OMjE0MjM4
  3. ianplymouth
    getting to know these cars quite well now :weary::weary: :laughing::laughing:
  4. You love the hassle
  5. ianplymouth
    i suppose i do :laughing::laughing:
  6. Make sure you get High velocity bearing, as when i rebuilt my gearbox all the ones i got were the correct size, but for low rotation speed use, had to get them changed again when my synchro's gave up and the guys told me the bearing were shot already after 6month on 5th and 6th gear as these are the PK4 weak points.
    Jamie230 likes this.
  7. Thanks for that I have ordered ‘uprated’ bearings for it as i had that worry.
