1. Hi All,
    Noticed on my drive home from work the drivers side bulb has gone pink, so I'm guessing that means new xenon bulb.. few questions on this however:
    -should I buy a pair and replace both at the same time?
    -I have an 07 R26 so would these be D2s or D1s?
    -Osram I'm guessing are direct replacements, what options from the below would be best?
    Option 1
    http://www.powerbulbs.com/product/xenarc-d2s-single
    Option 2
    http://www.powerbulbs.com/product/osram-night-breaker-unlimited-d2s-single
    Thanks in advance
    Dee
  2. It'll probably be D1s. My R26 is anyway. You can just about check by going through the arches.
    I just replaced the failed bulb with an osram xenarc bulb and it was a good match to the other bulb
  3. Thanks for that, will take a look at those and get something ordered
  4. If budget permits I'd replace them in pairs.
  5. They are D2S bulbs.
  6. Get a pair, osram is slightly better than philips. And watch out not to touch theglass part with hand
  7. Amd the Night braker unlimited is well worh it
  8. Mine weren't on my r26. They are d2s on earlier models.
  9. Thanks all for the advice, will take a look at the bulbs this weekend before I order them-to make sure i get the right ones, think I'm going to do the pair as it'll just bug me if I don't..
    The night breakers are the ones I like the look of, so it'll probably be a pair of them.. Payday Friday thankfully!!
    Thanks again for the advice
  10. Just as an info only update - took bulb out yesterday - it was a D1s on my 2007 R26.
  11. Those are FAKE, ie chinese bulbs... And cant compare to the OEM bulbs
  12. always worked for me!
  13. Have you known better or tryed genuine bulbs?
  14. yeah, seen plenty :smile:
