Did some Ph1 225's come with TRW rear calipers or did they come with ATE ones fitted? Just found out i have TRW on my PH1 and wondered if they had been replaced with PH2 rears? Either way they require a rebuild so can someone point me in the right direction of a rebuild kit for them? thanks
must have changed calipers and mounting brackets or fitted a ph2 beam. maybe a R26 if it has a anti roll bar attached https://brakeparts.co.uk/shop/Renau... - Brake Calipers and Wheel Cylinders/BCK3425 rear brakes are tricky to rebuild though as the handbrake mechanism is held in by a circlip at the bottom of where the piston sits
thanks @matt e I thought it was odd when i checked earlier to see what they was as i was thinking about intalling the TRW calipers. Good shout about the R26 beam. ill have a look for the ARB when im next out.
