Hi all only owned my r26 a week, took engine cover off this evening to notice previous owner has Totally bodged this sensor which I've heard is a common thing to brake when fitting a dump valve, does anyone know the part number or where I can get it from so I can get it sorted. Cheers
if it's the one I think it is ...I just had a price for it just the other day,and I need just the breather pipe on the other end of it...but you can only get it complete from renault and it was about £48 ...unless someone has a spare for you at a cheaper price
yeah was going to order one myself also. ..but I just need the breather pipe on other end to the rocker cover but I'm going to order the silocone kit for the breather system at the same price which is an upgrade
Did you end up ever getting this part # ? and is it for the full length including the two one way valves or just the actual plug in section that your previous owner so elegantly repaired? (*I've owned my 225 Cup a week and already snapped the one way valve towards the other end of that pipe attached the the end you pictured, trying to figure out how to replace it) ...I've circuled it in red (the masking tape is only so I don't forget about it )
