Oz Ultraleggera center bore
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by PTMRS, Aug 16, 2020.
  1. Hi guys!
    Does anyone know the actual size of the center of the Oz Ultraleggera wheels?
    I saw on the net that it's 75mm, but is it right or is it 75.1mm?
    And where can I buy the hub center rings? Can be in plastic, or aluminium it's better?
    What's the best size 18x8 or 18x9 wheels?
    And the best tire size for the wheels?
    Megane RS mk3
  2. Offset is probably just as important.
    Needs to be minimum 45mm to 50mm and I would stick to a maximum of 8.5” with the high offset.
  3. The offset it's 48... but Oz only have 8x18 and 9x18!
    And what about the tire size?
  4. Is your car lowered? 9” might be a bit to tight.
    8”J and 48mm offset is a nice fit with standard 235 40 18 tyres.
  5. Yep, I have 35mm H&R springs.
    I think it's better to stay with the 18x8 et 48, the 18x9 it's et 55!
    And with the 18x8 do I need some spacers or will be fine?
