Overspray on rubber window frame ?
Discussion in 'Exterior & Bodywork' started by Alcon, Aug 20, 2015.
  1. I got my 250 Megane used, noticed some overspray on the rubber window frame at the 3/4 rear windows and some at the Sunroof rubber lining. Looks like they sprayed the car without masking properly. Is this typical out from the factory ?
  2. No, the car is sprayed as a shell in the factory, there would be no trim in place...
  3. Any overspray on a car is a sure sign its been damaged in the past and re-sprayed.
    Worst case, the car may have been crashed; but it may have just been something small like a parking scruff or keying down the 3/4. Depending on colour, it's quite normal to have to spray an entire panel to get the repair to blend in.
