I've searched everywhere for one touch resetting, but none seem to work so has anyone had the same as me? Passenger side window (front and rear, it's a 2005 Scenic..), both work if you hold the up or down position to the first click. If you give a hard push or pull to do one touch, it stops. First click, hold it and no issue. Drivers side, first click and second click work as expected. Suspect it's the switch as every reset procedure I've tried isn't working, although I think ice tried them with the engine running if that matters?
