Oil temp gauge
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Umran9, Aug 2, 2016.
  1. Hi has anyone fitted an oil temp gauge to a megane r26? Would be interested to know where i can plumb in sensor probe
    Im fitting a mocal oil cooler kit so cant mount sensor in the sandwich plate as mocal sandwich plates dont have sensor ports, Dont want to use sump plug as ive got a magnetic sump plug. Is it possible tee on factory oil switch?
    Thanks in advance
  2. matt e
    can you not get a sandwich plate thats thermostat with sensor ports
  3. I'm using a Mocal Thermostatic sandwich plate which doesn't have additional ports for sensors etc... I may get the sandwich plate drilled and tapped as a last resort!
  4. my mechanic has done as you described and it works fine
  5. Which part of the plate did he tap into?
  6. Buy a sump plug with the fitting tapped into it. LMA do them on Demon Tweeks.. All you need to know is the sump plug thread size and the sensor thread which you choose..
  7. Ive got a magnetic sump plug! Ive got it sorted now bought a kit of Proline Motorsport with a Mocal sandwich plate tapped for a sensor probe... Happy days
