quick one guys.,is there a sensor i can disconnect to allow cranking but no fuel and no start. done an oil filter relocation and would like to get oil around everything prior to firing.cheers
I'm sure it does, my engine would still run with the crank sensor is disconnected, but nothing when the cam sensor is unplugged
it won't matter if the sparks work it's the fuel you need to turn off, especially if you have a cat fitted
