Oil leak
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Supersibot, Jun 19, 2018.
  1. Hi all,
    Open to suggestions as to where this oil leaks might becoming from. The photos is taken from the drivers side front wheel well looking at the drive shaft. The oil (hard to see) is on the block behind the drive shaft.. Seems to be coming from cambelt area... Any common issues? Nothing really visible from above. Cheers in advance.
  2. Its a 265 cup.. Forgot to mention!
  3. Could be from sump or someone’ done a sloppy oil filter change and didn’t clean up properly
  4. Crank seal behind crank damper pulley, maybe
