I seem to have a slight oil leak from a sensor next to the coil pack/spark plug nearest drivers side anyone know what the sensor is, is it prone to leaking and is it just the bolt out and lift out to check o-ring etc.
Thanks mate, I'll pop up the dealers and order that and have a look at the new megane 280 while I'm there. Sent from my AGS-W09 using Tapatalk
mine was same, just removed solenoid, cleaned inside and gently cleaned rubber seal been dry for over year now
