oil cooler
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by matt e, Oct 25, 2017.
  1. matt e
    does anyone know the port sizes on the modine oil cooler where the oil filter is located
  2. These any good to you Matt? 51488702c748505350e2a01ddc50a99f.jpg c2afbcf48e271aca6e72ee9ed4070608.jpg a47a0be5fa37cb9466ea1a014119562a.jpg 0ee2ecc4ebf63449147731469ebbaeca.jpg e39fbdf006cc7276e4002095775a5159.jpg
    matt e likes this.
  3. matt e
    Yeah that's brilliant. Cheers!!!!
  4. matt e
    @Gray you've removed this havent you? did you just screw in the insert or use any thread lock on it?
  5. Gray
    Gray RSM Moderator
    I planned to remove it, but ended up re-fitting / running the OEM set-up.
    I've still got a Mocal thermostatic sandwich plate and oil cooler in the garage... I'll probably fit over winter, if needed.
  6. I would run both of them. The water-oil will heat up the oil quicker, and the dedicated air-oil cooler will keep the oil cool
    Sent from my LG-H870 using Tapatalk
    Trophyboy likes this.
