250 Oil breather hose leak - advice on replacement?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by FramerateUK, Dec 29, 2014.
  1. Hey guys,
    I've had a strange smell coming through when the heater has been on, I guessed it might be oil, and I've possibly found the culprit.
    There's a definite leak form my oil breather hose from the engine to the airbox.
    Here's a video to show how loose the pipe is:
    https://plus.google.com/u/0/photos/...6098353858698382482&oid=101564450020794482865
    And a photo for good measure:
    https://plus.google.com/u/0/photos/...6098353920367985138&oid=101564450020794482865
    I'm guessing this should be tightly attached yes? There's nothing holding it in place, only the fact that the cable attached is resting on this direction. Should it have a jubilee clip or something attached to it too? The other side of the hose is also leaking, though I cleaned it before taking the photo.
    Does anyone know the correct size of this hose, and what I should be looking for as a replacement? Any links would be very much appreciated!
  2. TimR26
    It needs a couple of jubilee clips to secure it if the hose isn't damaged.
  3. Good call! Makes more sense than replacing it. The hose itself is fine other than it's not a tight fit anymore. I'll dig out some clips today and see if I can find one that fits properly.
  4. i have same problem long time ago . Strange smell when i stop on red light . I change same hose and noting . 2 weeks i try to solve problem . I check every hose 3 times . I found problem using soap foam . Lot of it .. Spark plug was loose . :smiley: local Renault service forget to secure spark plugs . All 4 loose
