225 OEM spark plugs
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Liddell92, Apr 29, 2017.
  1. Hey,
    So I'm looking at replacing my spark plugs.. cars done a lot of miles and I have no idea when last replaced. Are OEM the best way to go?
    Will there be any noticeable differences when replaced? I've noticed my car doesn't drive smooth when in traffic thought it may be because of this
    James
  2. Yeah oem are best or if you want a bit of an upgrade you can get the irridium type.
    You may notice a bit.of a difference all depends on how bad the originals are!
    When I did mine I thought it pulled a bit better at low revs
    Sent from my FRD-L09 using Tapatalk
  3. Ah so Renault do iridium ones? Yeah I'm curious to see! My cars done over 100k.. they might be the originals [emoji15] ah ok so some difference!
  4. Not renault but ngk/ denso do. Ngk do the oem ones (just in a renault box) which are platinum tipped (from memory)
