This has been covered a couple of times just have a search Wheel and brakes off, undo the bolts on the bottom of the hub to split it, track rod end off, unbolt the drive shaft bearing mount and pull it out. Job done. Just remember to take the drive shaft but off before you take the brakes off if you don't have air tools.
