Number plate light not working
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Josh_s 1991, Dec 31, 2018.
  1. I've upgraded my number plate light bulbs to led. But one side has blown so only one side working. When I changed them it was very difficult to get the plastic casing of i used a key to do this and fractured the bit of plastic. Does anyone know of a tool I need to help me and another bit of casing to replace broken one? Thanks alot any help much appreciated
  2. The casing comes with the bulb from renault as a whole replacement unit
    They shouldn't be hard to remove, just use a flat bladed screwdriver to press the tab in
  3. I managed to prise it off with a sharp file. My mate had to replace the whole unit with loom to sort it as they rust
    I presume it was ok before you changed the bulbs
    Sent from my SM-G950F using Tapatalk
  4.
  5. Yes it was fine although it was a yellow light and I wanted a brighter white light. Anyone know what size they are ? 501's ??
  6. Yup 501, same as the interior bulbs
    Josh_s 1991 likes this.
