Non returning clutch pedal on track?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Stock265cup, Jul 26, 2019.
  1. Have had this happen twice now. After being out on track for a while the clutch pedal would not return to its normal position by itself. Clutch still worked ok and was fine after coming into pits and is fine in normal driving after trackday. Happened to me at Castle Combe a while ago and recently at Bedford, both days were pretty warm Castle Combe was mid 20s ambient temperature and Bedford high 20s/30 degrees C.
    Anyone else had this happen or know what could be causing it? Any info will be greatly received.
  2. Fluid boiling? You using standard brake fluid ?
  3. No, I’m not using standard brake fluid.
  4. I've had this once on track as well, the clutch pedal stuck to the floor. Was fine soon as I pulled it up with my hand.
