noise when turning from lock
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by jay26, Sep 21, 2016.
  1. getting a quiet "dum dum dum " type of noise when returning from lock when coming out of a junction ,doesent happen all the time ,seems mostly when turning the wheel slowly and at low speed
  2. Front springs?
  3. i was thinking this noise is not half as loud as a broken spring , i did have a feel to see if one had broke tho and the one on the near side had the rubber coating torn thats on the lower coils . springs felt fine tho ?
  4. Jack it up and put it on stands and see if it still does it.
    You'll be able to investigate further then.
  5. Development in the noise , its only doing it just after its been started . wont do it in reverse at all and only does it after i set off forward after a couple of feet and only the once wont do it again till i park it up and leave it for 10 mins or so and go to leave again ???
  6. Abs self check.
    It's fine, they all do it
    jay26 likes this.
