R26 no power over 2500 rpm
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by gjonmat, Feb 21, 2014.
  1. As it says my lads r26 has lost power over 2500 ish could it be coil pack? He took it to our local rip off garage i told him to get it back they charged him £24 for "putting it on the fault finder" and they never told him what it was, oh well his fault but my first guess is coil anyone else got any clues i did rev it stood still and it seems to miss fire
  2. Any message on you comp screen?
  3. Will.
    Limp mode.
    Could be coils, a sensor, solinoid or anything.
    Best thing to do is get it on a clip and find out the fault codes that appearing.
  4. I've got clip mate. :smile:
  5. Damb bad timing as mine in in for clutch tomorrow so i cant do awt but i have the orange thing off ebay fault reader thing bd code reader thing just dont know how to use it with 3 meganes in the house i guessed it would be a good idea to get one :smile:
    lee if i was free tomorrow i would pop over, maybe sunday if your free and my reader has no joy
  6. oh will your clip put my auto lights back on? after trip to humberside renault they are on all the time tossers!!
  7. Hold the indicator stalk button in to do that mate.
  8. I'm about on Sunday. Tomorrow is no good for me. I'm down in Chelmsford until tomorrow night.
    Lee
  9. Great cheers lee i will look at popping over sunday if that is ok
  10. Pm sent
  11. cheers lee tried to send p/m but dont know if it worked so will give you a shout sunday :smile:
  12. how does this work does it also reset your wipers as mine aren't the same as they used to be don't work anywhere near as well as they used to ? I have tried before but nothing seems to happen
  13. Quick update had it next to mine did the normal coil swap ect and nawt so i took off the ribbed pipe (what would be the T d/v pipe) and its fine, so i guessed it had a intercooler block so i got my old intercooler and all pipes changed and its still the same :-(
  14. Just been told it still misfires with the pipe off but not as bad
  15. Did your OBD reader throw any codes up?
  16. Don't know how to use it
  17. It should be a piece of piss mate, pop the OBD port cover off (in front of the gearstick) Plug it in, then yoou'l prob have 3 or so buttons two to scroll one for enter, scroll to DTC press enter.
    Is your code reader an orange one with a cable attached?
  18. Oh depending on the type you may need to have your ignition on (but not the engine running). i think thats press the start button 3 times with key in and hold down the last press of the start button for about 10-15 secs
  19. Its the orange one i will have a go, watch this space......... Ps cheers
  20. P0235. P 01/01
  21. 0 fault
    1 pending
  22. P0235 says -
    Boost pressure sensor harness is open or shorted
    - Boost pressure sensor circuit poor electrical connection
    - Faulty boost pressure sensor
    - Faulty Turbo/Super Charger
    - Engine over temperature
    - Ignition misfire exceeds the calibrated threshold
    - Faulty Knock sensor (KS)
  23. Where is the boost sensor?
    And where is the knock sensor?
    Lucky i have my car to swap the two and rule it out
  24. The pending bit means you've got an intermittent fault that has been logged in the ECU but hasn't hit the threshold to actually register it as an actual fault yet
  25. Knock sensor is on the front of the block near the oil filter, from memory it has a brown electrical plug going into it (may be wrong, so don't quote me!).
    Boost sensor i would presume would be the MAP sensor, which is on the plastic hose going into the throttle body it may be hidden down behind the headlight somewhere (I've got the forge hard pipe kit so cant 100% remember exactly where it is) you'l probably need a small flat head screwdriver to prise it loose
  26. Cheers i will have a look
  27. No worries, i'd probably start with the Map sensor first tbh
  28. I changed his for mine earlier and it was the same so knock sensor next
  29. I'd also be looking at the n75 valve as i think the solenoid has a habit of going every now and again from what i've read
  30. Sounds like your having a mare austin any luck selling the r26 yet ?
  31. Unsure what he doing with it think he saw his arse with it coz it has this problem, what's a N75 valve?
  32. Were u taking both to fcs ?
  33. Yup, i am for sure if he still got his and depending where he gets based (raf) he will take his
  34. U gonna be camping ?
  35. Well i have looked into both and for £86 each me and my mate it will cover fri/sat night in a travel lodge and camping if we wish and the entrance fee good eh, best of both
  36. Interesting im getting more temted too make it u gonna be starting a convoy
  37. Your opposite side of the country to me
  38. I've got a spare n75 valve sat on my desk. We will sort it Saturday mate. :smile:
    lee
  39. Great cheers lee
