R26 Need help!
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Matt-f1, Aug 5, 2014.
  1. Fitted a new window module today to my car and it worked fine! I then put the door card back together and locked the car and the window went down instead off doing the window up "pinch" and now won't do anything! Is there anything I can do or is this broken again??
    cheers matt
  2. I'm guessing that the regulator (module?) wasn't the cause of the original failure, and that a bad connection was. You have disturbed this which made it work temporarily but now it's stopped again.
    Take the door card off again and 'play' with the connections is something you could try.
  3. All fixed now one of the window switch wires was trapped causing it to not work! Thanks for the reply's anyway!
