My window only winds a little at a time?
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by RedSquareImages, Apr 23, 2014.
  1. My car battery died recently. Following this my driver side door window will only wind down a little at a time. Is there a way I can reset this?
    Kev
  2. Yep Hold the window button up for about 15 seconds, this will reset.
  3. Ash87
    As above, simple fix.
  4. Usually does this if you disconnect the battery or lose power, as above 15 seconds with the switch up and it'll go back to normal.
    That is unless it's my 225 which decided the drivers window opening at all was overrated and stopped when I changed the battery!! lol
