Right then guys got some seats on the way and harnesses, how do you guys without cages mount them?? Any ideas? Safety is priority
alot of people including myself use these.... http://www.msar.co.uk/motorsports/H...Harness-Hardware/Schroth-B23A-Bracket_88.html you can use an eyelet on the outside/door side of the seat frame for one lap strap, the difficulty is down the tunnel with little space. To get another eyelet in for left strap. You can always drill the side mounts like how the .R have the harness fitted Have you ordered subframes yet? I'm actually getting some made start of next month which will make it easier to use eyelets for lapstraps both side, it'll also suit wider seats as ktecs subframe have very little room for modifying to fit wider seats. the ones I'm getting made also allow for 6 point harnesses to be made. I'll text you more details of your still looking for a set of subframes. The shoulder straps usually you can use the seatbelt mounts with eyelets I haven't got any pics but I'm sure others will add some for you lol
I have the rears seats removed,and the harness use the same holes/bolts. You could also use a harness bar.
Cheers Chris and Oldfella, I've already ordered Ktec frames Chris now and the side mounts that come with my seats. Looking at others they look compatible as other have had them fitted. These are the harnesses I have bought, OMP 3inch harnesses
