MOT Failure help
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by 3hirty8ight, Jun 12, 2015.
  1. 2007 R26 Megane 230 F1
    Hey folks,
    Megane failed the MOT on a snapped front coil spring today. - Literally only a inch section off the drivers side.
    Taking the opportunity to have a bit of a freshen up a the front end.
    Does anyone have the genuine part numbers for:
    Front shocks
    Springs.
    Top Mounts
    Standard items.
    Thanks,
    Henry
  2. So far I've found:
    Front shocks 8200647895
    Springs 8200647852
    Top mounts 7701209530
    Is that correct? - Also is there any difference betwwen the 225 and 230 items?
    Thanks,
    Henry
  3. I've got a full set of front and rear suspension taken off 47K r26, all in perfect working order.
  4. Cool, would you part with the front springs, as long as they are in 1 piece! ;-) ? - Ideally want new dampers and top mounts..
  5. MBC
    MBC
    The suspension is completely different on the 230 they use Eibacks
  6. 225's with cup and trophy pack use the same dampers and springs as the r26 from what I can gather?
  7. Yeah cup packed and r26 are the same iirc
  8. Can anyone confirm the above part numbers are correct for the R26?
  9. Nice one Gio!
