Mk4 calipers.
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Chris79, Nov 5, 2020.
  1. Can anyone clarify the difference between mk4 brembo calipers (front) And mk3? These will be for a mk 2 upgrade, will be using mk3 discs. Appreciate part numbers aren’t the same so there must be a difference but what? Is it just the offset to allow for the larger 355mm discs? If that’s the only difference I suppose the caliper spacer size could sort this? Cheers
  2. sure they use the same pads though
