Hi Guys Running 1st track day in the Megane Sunday, also running a set of AO50s on aftermarket 18's 235/35/18's Whats the best pressures to set them, cars 1300KG with me with BC's running almost 3 degrees front camber, 2mm toe. Guides say 29 - 31 Hot. i've used them on my clio but just little 195 / 205 / 50/15's I normally run the fronts 21 PSI cold and that gets them to 27 after a session - Rears I use to run the Clio 24PSI cold and that got them up to 29 after a session Do you guys with Meganes and AO50s pretty much see the same increase? or should I aim lower / higher cold temps? I'm in Australia so track will be warm Outside temp mids 20s but strong UV this time of year Thanks in advance.
