Mk3 Rs radiator bleeding
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Wmrs250, Mar 4, 2015.
  1. Is their a simple way to bleed the coolant system, I can't seem to locate a bleed screw and trying to get the air out through the expansion bottle is taking forever
  2. matt e
    Is it not by the thermostat?
  3. I've just fitted a new thermostat, I didn't see any bleed screws or valve just the three bolts holding the housing on
  4. Unsure on the mk3's but as its still an f4r i'd imagine its in a similar place to the clio's/ mk2's which is a 10mm bolt near the thermostat think its just above the TDC sensor
  5. There is a screw on the coolant pipe that runs into the bulkhead. I know this from a leak i had after a radiator replacement.
  6. matt e
    this the one on the mk2, unsure on mk3
  7. Follow the right hand side of the engine cover to the back, look behind the gubbins behind it & you will see 2 pipes running into the bulkhead (attached with green clips). On the right one there is a screw on the top front of it.
  8. Cheers lads, will have a look tomorrow
