MK3 RS 6 - POINT HARNESS INSTALL
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by LewisIrvine, Feb 23, 2018.
  1. I have just bought some Sabelt 6 - point harness and I am trying to figure out how to fit them to the Meg. Any help would be appreciated :smile:
  2. APM
    APM RSM Trader
    There are many options. Firstly...
    Shoulder straps
    Do you have a rear cage? Wrap around harness bar if so. If not, eye bolts to the 4x points found in the rear seat wel is the easiest.
    Lap belts
    1 side of lap belt fitted to the gearbox tunnel with welded plate or sandwich plate on the under side. The other side you can use the existing 3 point seatbelt base anchor point with eyebolt.
    Anti-sub belts
    Ideally again, welded plate or sandwich plate on the underside of the floorpan with eyebolt attached. This would be directly under the seat.
  3. Thank you :smile:
  4. -Jamie-
    Ditch the crotch and just run them as 4 points, 6 are an utter pain in the arse on the road.
    Should be easy enough to swap the buckle if its on the anti sub belts onto the lap
